Interface Queueing Diagnostics
Nov 18th, 2008
I have a Cisco 1700 Router which acts as a Gateway to an application in which multiple users from our network access. The application is hosted by another company and so I have no access beyond this router.
The inside area our network is on the side of a 2Mbps Serial Leased Line connection.
The outside is the side adjacent to the companies LAN of the hosted service. This is a Fast E 100Mb.
I am seeing input queueing drops on the interface which connects their server farm and many of my users are complaining of slow connection to this system.
What could be the cause of this high number of input queue drops? Could it be to do with input errors from their switch or is this becasue the buffers are overflowing in the input queue?
Any help would be much appreciated.
FastEthernet0 is up, line protocol is up
Hardware is PQUICC_FEC, address is 000d.bd64.b471 (bia 000d.bd64.b471)
Description: Outside LAN @ **** Site A
Internet address is *********/**
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 4w6d
Input queue: 0/75/1062984/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 697000 bits/sec, 252 packets/sec
5 minute output rate 447000 bits/sec, 276 packets/sec
259094706 packets input, 2129952001 bytes
Received 41521197 broadcasts, 0 runts, 0 giants, 0 throttles
890 input errors, 0 CRC, 0 frame, 890 overrun, 0 ignored
0 watchdog
371816065 packets output, 2030182445 bytes, 22 underruns
22 output errors, 0 collisions, 0 interface resets
0 lost carrier, 0 no carrier
Serial0 is up, line protocol is up
Hardware is PowerQUICC Serial
Description: *** 2Mb Link ****** to ****** House
Internet address is ********/**
MTU 1500 bytes, BW 2048 Kbit, DLY 20000 usec,
reliability 255/255, txload 87/255, rxload 56/255
Encapsulation HDLC, loopback not set
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 7154
Queueing strategy: weighted fair
Output queue: 1/1250/64/7154 (size/max total/threshold/drops)
Conversations 1/97/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1843 kilobits/sec
30 second input rate 457000 bits/sec, 349 packets/sec
30 second output rate 699000 bits/sec, 265 packets/sec
372452578 packets input, 2728433827 bytes, 0 no buffer
Received 350486 broadcasts, 0 runts, 0 giants, 0 throttles
8 input errors, 2 CRC, 0 frame, 0 overrun, 2 ignored, 4 abort
220684815 packets output, 212333463 bytes, 2 underruns
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Overall Rating: 5 (1 ratings)
drolemc Tue, 11/25/2008 - 09:00
  • Silver, 250 points or more
You can successfully troubleshoot input queue drops while packets constantly arrive in the input queue. You cannot troubleshoot a congestion that occurred in the past. If more than one routed protocol is configured on the interface, first determine the protocol that congests the input queue. Here is the fastest way to do this is.
1. Determine the suspect protocol. Check the CPU utilization in Input processes. To do so, run the show processes cpu exec command.
2. Find out whether packets that congest the input queue are destined for the router, or are forwarded through the router. Run the show interfaces [type number] switching command from exec mode. (Type Full command)
3. If packets are destined for the router, find out which higher-layer protocol congests the input queue. For this, use one of these show traffic exec commands:
For further information click this link.
http://cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml#topic3
