SNMP V3
Nov 18th, 2008
I have configured SNMP v3 in my Cisco 3560 switch and added it into OpManager monitoring tool (supported SNMP v3).But it's showing SNMP not enabled in that device.SNMP v1 working fine.
Please find my SNMP (v3) configuration and let me know if I missed anything.
Switch(config)# snmp-server group admins v3 auth read adminview write adminview
Switch(config)# snmp-server user root admins v3 auth md5 secrte12 priv des56 secrte21
Switch(config)# snmp-server context opmanager
Switch(config)# snmp-server host 10.138.75.136 root
10.138.75.136 - OpManager server IP
som
Please help to resolve this issue.
Joe Clarke Tue, 11/18/2008 - 09:05
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You did not post the configuration for the view adminview. Additionally, make sure OpManager supports SNMPv3 authPriv. Many applications which support SNMPv3 only support SNMPv3 authNoPriv.
somnath21 Wed, 11/19/2008 - 02:38
as per your guideline I have added the below mentioned lines..
snmp-server view adminview internet included
snmp-server view adminview ipAddrEntry included
snmp-server view adminview ipRouteEntry excluded
** Attached screen shot of Op Manager.
But the issue is not resoved..
plz guide in this matter..
regards,
som
Joe Clarke Wed, 11/19/2008 - 09:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
First, this view is not sufficient to manage a Cisco device. You should consider using the built-in view v1default which will grant you all required MIB access. Second, udp/162 is not the correct port for SNMP. The SNMP agent binds to udp/161 for manager requests, and uses udp/162 to send SNMP notifications (e.g. traps).
