WAAS - NME Implementaion confirmation question
Paul Pinto
I would just like to confirm if there is any reason why using a /31 mask would not work with an NME using WCCP? If not, what the reason would be.
I don't believe this would work with the Appliance on it's own VLAN, probably at least a /29??
Thanks in advance.
7 Replies 7
Paul Pinto
Hi again,
I hope my query is not to ambiguous or sounds trivial.
I would just like to confirm it.
Thanks again.
ropethic
Level 4
Level 4
You will need a least a /30
With a /30 you get 2 host addresses.
So lets say network 0, host 1 and 2. x.x.x.1 for
the gateway, 2 for the NME, WCCP router list x.x.x.1,
Here is a sample config
R2821-edge#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
R2821-edge(config)#int integrated-Service-Engine 1/0
R2821-edge(config-if)#ip address 10.10.100.1 255.255.255.252
R2821-edge(config-if)#service-module ip address 10.10.100.2 255.255.255.252
R2821-edge(config-if)#service-module ip default-gateway 10.10.100.1
R2821-edge(config-if)#ip wccp redirect exclude in
R2821-edge(config-if)#exit
R2821-edge(config)#end
R2821-edge#copy running-config startup-config
Hi Robert,
Thanks again for the prompt response.
I am OK with the general required config, it's the mask I'm querying. I'm being told the /31 would be OK. So, below is the intendended config in question (using your example host range of .1 and .2):
R2821-edge(config-if)#ip address 10.10.100.1 255.255.255.254
R2821-edge(config-if)#service-module ip address 10.10.100.2 255.255.255.254
This works with Point-2-Point links and the likes, but with the NME? This is where my query lies.
Thanks again for the assistance.
with a /31 you only get 1 subnet address and that would not allow for the NME WAE and gateway to be on the same network.
if int engine is 10.10.100.1 whta will you use for an address for NME service module?
i guess you could /31 with 10.10.100.2 but will need a default route on the NME to get to the default gateway or simply have a L2 connection to the between the wae and integrated service engine.
It would probably work, but not sure why you would not want to use a minum of two address
You need an IP on the NME for CMS registration back to CM. It has always been Cisco best practice to put engine and module on same net
Hi Robert,
Thanks again for the promt reply,
Like you say, there are the two adresses, and it would probbaly work, but it's not best practice, so I was just looking for some confirmation on the best practices which you have provided.
Will let you know the outcome soon.
http://www.cisco.com/cgi-bin/Support/IpSubnet/home.pl
URL for subnet calculator
/31 will only give you one address.
As long as the router can see the nme in wccp group, it should be fine.
All routers with ip wccp 61 & 62 will be part of the same group. With the NME and Appliance, you just need to provide the wccp router list.
I will try in my lab also.
when done, do a show wccp routers on wae
if router shows up then you are fine. WCCP will use the highest IP address of an interface to identify itseld to WAE
Were you able to try this in the lab yet?
Thanks again for the prompt responses.
