URL for Idle services for IP PHONE in CUCM 6
Nov 18th, 2008
I have loaded file cisco.xml into TFTP folder. It's a picture.
Now I use url http://<IP CUCM>/cisco.xml
but nothing work. Does this solution is the same like in Callmanager 4.1 or there is some difference?
Thank you a lot!
stephan.steiner Tue, 11/18/2008 - 05:00
  • Silver, 250 points or more
Can you access http:///cisco.xml from your PC? I suspect not - I'm not aware that the TFTP directory is mapped to a directory on the webserver running on the CCM so I think you need to place that file on another machine that has a webserver running.
