OU Change for Unity 4.2
Nov 18th, 2008
We are having Unity version 4.2 working in Active/Standby. These are part of an Organisational Unit of our existing Enterprise Active Directory. Now we want to move these into a different Organisational Unit.
Is it possible? If yes, what are the steps and what all precauitions we have to take for the same.
Please advise.
Manu
Tommer Catlin Tue, 11/25/2008 - 18:11
It depends, if you move the "Locations" OU where Unity places it's unique identifier for it's location, then you will need to update Unity. I dont think it will get the update from AD.
As for service accounts, you should be ok.
