practical exprience regarding static map ?
Nov 18th, 2008
pl share knowledge that without configured any static map from outside side ( private IP) not internet can access behind Pix firewall ?/
anyone have doing practical experience ?/.
hadbou Tue, 11/25/2008 - 07:22
Can you clearly explain the issue about which you have the doubt so that we can understand the issue and help you better.Also if possible provide the network setup which will be more helpful.
MATTHEW BECK Tue, 11/25/2008 - 14:08
If I understand your question...
The default behavior for ASA and PIX is to block all traffic from the outside to the inside unless you have a static command AND an access list permitting traffic.
The default behavior for traffic going from the inside to outside interface is unrestricted as long as there is a NAT and Global statement in place.
