Pix 535
Nov 18th, 2008
Having a problem trying to get print sharing to work from DMZ to inside network host that has printer attached to it. From inside to dmz works fine. Dmz to inside cannot attached to shared printer any ideas. I'm using a nat address from dmz to inside as well to inside host. A windows server 2003 is what we have as a web server in the dmz incase you need info.
Collin Clark Tue, 11/18/2008 - 06:33
I think that a printer share uses the same port and protocols as a regular Windows share. That's a ton of ports (RPC uses dynamic ports 1025 - 65535) to open so you may want to look into RPC over HTTPS.
Hope that helps.
