UC520 and PABX Lucent
Nov 18th, 2008
Can i connect an UC520 (UC520W-8U-2BRI-K9) and a LUCENT EUROGENERIS PABX with BRI interfaces ?
What protocoles can i use to do that ?
Do you have sample configuration ?
Thanks for your help.
shrutid22 Tue, 11/18/2008 - 17:58
I think 2BRI on UC500 are voiceBRI cards hence thats not a solution.
You need something to TRUNK between two systems. Think about FXO/FXS if the calls are not too much
jpaf Tue, 11/18/2008 - 23:52
On the IP telephony Network, i have only 3 IPPhone. i need only 2 simultaneous calls.
i only want to test this IP telephony solution.
Where can i found samples configurations ?
Thanks for you help
