Higher CPU? - Advance Enterprise vs. Advanced IP
Nov 18th, 2008
Let's say you have 2 identical 6500's under the same load, one running Advanced Enterprise, the other running Advanced IP. Will the CPU of the Advanced Enterprise switch average a higher utilization than the one running Advanced IP?
ropethic Tue, 11/18/2008 - 10:30
  • Silver, 250 points or more
Depends on what features gets punted to the CPU (software switched)
For both versions most features are hardware based across ASICS not requiring CPU processing.
royalblues Tue, 11/18/2008 - 10:51
  • Green, 3000 points or more
Yes it could be..
The enterprise IOS may be supporting/starting more services which requires a certain amount of CPU (though it will be less)
Narayan
