UC520 and C3750
Nov 18th, 2008
Hello All,
I am building an IP Telephony solution for one of my customers for 15 users in Shanghai. The solution that I came up is using a UC520-48U-12FXO-K9 with a WS-CE500-24PC but they want to go with a WS-C3750G-24PS-E which is the standard that they use in all other sites (Mostly in Canada and US). My question is; would UC520 works well with a C3750? Is there anything else that I have to consider for using C3750 with UC520?
MK
Overall Rating: 3 (2 ratings)
Brandon Buffin Tue, 11/18/2008 - 08:06
  • Purple, 4500 points or more
The 3750 will work fine with the UC520 and I think most will agree is a much better switch. The Catalyst Express switches have some quirks and haven't been real well received.
Hope this helps.
Brandon
mightyking Tue, 11/18/2008 - 08:19
Thanks Brandon,
If I want to provide redundancy, all I need is to go with two UC520?
Brandon Buffin Tue, 11/18/2008 - 08:32
Yes, you can provide redundancy with two UC520s using HSRP between them. In my opinion, this may be overkill for the small/branch office, but it obviously depends on the critical nature of the business.
Brandon
