Configuring Radius server on catalyst 2960 for authentication
Nov 18th, 2008
kindly suggest me how to configure the radius server on catalyst 2960 switch. need to know the exact commands. If possible kindly suggest me some white paper link also.
ropethic Tue, 11/18/2008 - 12:38
This example shows how to configure one RADIUS server to be used for authentication and another to be used for accounting:
Switch(config)# radius-server host auth-port 1612 key rad1
Switch(config)# radius-server host acct-port 1618 key rad2
This example shows how to configure host1 as the RADIUS server and to use the default ports for both authentication and accounting:
Switch(config)# radius-server host host1
