Netflow Config
Answered Question
Nov 18th, 2008
is there a way to have netflow send info on specific ip addresses (strictly in the config of a router). I will be trying to do this on a 2801.
Any feedback would be appreciated
Correct Answer by Giuseppe Larosa about 8 years 4 months ago
hello Dwayne,
there is no support of an export filter in netflow at least in this kind of routers.
However, on the collector software you can build a filter from the GUI or you can process the ASCII format of the files from shell in order to grep what you want: it becomes a problem of filtering text files looking for some pattern that is the specific flow you look for.
In each file you can find 0,1 or multiple occurrences of the flow.
Hope to help
Giuseppe
Correct Answer by glen.grant about 8 years 4 months ago
Not that I know of, usually your flow collector will some capabilities like that to filter what you are looking at .
Correct Answer by royalblues about 8 years 4 months ago
Do you mean the router should send the flow statistics for only a particular set of conversation?
IF this is what you mean, then unfortunately this is not possible
Narayan
Overall Rating: 5 (3 ratings)
Correct Answer
royalblues Tue, 11/18/2008 - 09:04
  • Green, 3000 points or more
Narayan
Correct Answer
glen.grant Tue, 11/18/2008 - 09:04
  • Purple, 4500 points or more
Correct Answer
Giuseppe Larosa Tue, 11/18/2008 - 09:52
  • Hall of Fame,
    Founding Member
hello Dwayne,
Hope to help
Giuseppe
