Cluster ip address not accessible from outside interface
Nov 18th, 2008
Hi ,
I have replaced my pix-515e with asa5520-k9(Version 8.0(3)6).
I am facing an issue where i am having two servers on inside which r clustered.
From my outside interface i can connetct to server1 and srver2 but not the cluster ip.
I have natted all the three ip addresses statically.
Ur help needed as i caanot connect to the cluster ip,my application is not working.
static (inside,outside) netmask -----cluster ip
I cant access the cluster ip address but access the physical ip address.
panzhixin Tue, 08/11/2009 - 21:45
I have the same problem with you.
how should we do when the ssl vpn connection across the nat.for the cisco ssl vpn cluster uses a redirect technique, so it can't keep the session when the nat happen . So I think , in the nat environment, cisco ASA couldn't support cluster
robertson.michael Wed, 08/12/2009 - 07:14
Hi Mahesh,
In addition to the static lines you mentioned, you also need to verify that your access-lists are configured correctly as well.
If possible, please post a sanitized copy of your config and we might be better able to assist.
