11-18-2008 08:59 AM - edited 03-15-2019 02:37 PM
How many outside calls can we make in a conference call with CME and CCM ?
thanks
Solved! Go to Solution.
11-18-2008 10:00 AM
Hi Okan,
Before Cisco Unified CME 4.1, support for conferencing is limited to three-party ad hoc conference calls using a G.711 codec.
In Cisco Unified CME 4.1 and later versions, multi-party ad hoc and MeetMe conferences allow more than three parties.
From this excellent CME doc;
Cisco Unified Communications Manager Express System Administrator Guide - Configuring Conferencing
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html#wp1010335
Hope this helps!
Rob
11-18-2008 09:23 AM
there is no fixed limit to this as it depends on CFB being used, if using G711 and SW CFB you can go as far as 42 per conference if you configure it that way.
if using HW CFB up to 8 participants with different codecs, if SW CFB + XCODER depends on stream codec and xcoding resources along with max number of users per conference
read the SRND media resources chapter for more info
java
if this helps, please rate
11-18-2008 09:38 AM
what about call manager express?
11-18-2008 09:42 AM
built-in 3 way conference, HW same as CUCM
plenty of info available on CCO and NetPro if you dig a little
java
11-18-2008 10:00 AM
Hi Okan,
Hope this helps!
Rob
