Easy VPN goes down on the DHCP connection
Nov 18th, 2008
Hi folks,
I am starting to pull out my hair in the attempt to understand why the router's interface goes administratively down when the easy VPN client drops the tunnel.
Here's the excerpt from the router log when it happens:
086251: Nov 18 01:04:08.705: %CRYPTO-6-EZVPN_CONNECTION_DOWN: (Client) User=Store1301 Group=Stores Server_public_addr=xxx.xxx.xxx.145
086252: Nov 18 01:04:10.689: %LINK-5-CHANGED: Interface FastEthernet4, changed state to administratively down
086253: Nov 18 01:04:11.689: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4, changed state to down
086254: Nov 18 01:04:13.692: %LINK-3-UPDOWN: Interface FastEthernet4, changed state to up
086255: Nov 18 01:04:14.692: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4, changed state to up
086256: Nov 18 01:04:18.811: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet4 assigned DHCP address xxx.xxx.xxx.87, mask 255.255.255.0, hostname 1301_Lascolinas
086257: Nov 18 01:04:19.582: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.145 has no SA and is not an initialization offer
086258: Nov 18 01:04:20.374: %CRYPTO-6-EZVPN_CONNECTION_UP: (Client) User=Store1301 Group=Stores Client_public_addr=xxx.xxx.xxx.87 Server_public_addr=xxx.xxx.xxx.145 NEM_Remote_Subnets=10.13.1.128/255.255.255.128 10.13.1.0/255.255.255.128
FastEthernet4 is configured to receive an IP via DHCP. I checked the lease time and it turned out to be pretty short:
1301_Lascolinas#show dhcp lease
Temp IP addr: xxx.xxx.xxx.87 for peer on Interface: FastEthernet4
Temp sub net mask: 255.255.255.0
DHCP Lease server: 192.168.0.1, state: 4 Rebinding
DHCP transaction id: 660
Lease: 600 secs, Renewal: 300 secs, Rebind: 525 secs
Even if it is short the router should renews its IP and it is not supposed to bring down the interface.
Is there any way to use a loopback interface for easy VPN client so that VPN always stays up?
Sincerely
Eugene
The loopback interface can be set to use the easy vpn client.
The command used for assigning loopback interface is
Router(config)#interface loopback
The number can be between 0 and 2147483647
A loopback interface is automatically put in "no shutdown" state when created. However, you need to assign an ip address to use a loopback interface.
