sfp issue to connect to cisco 2960
Nov 18th, 2008
We bought two Cisco 2960-48TC-L, I have issue with gi0/1 and 0/2. the sfp won't stick into the port firmly, you have to press the it in order to get the light,try with second 2960, the same result, yet, tried some other 2960 we got few month ago, it works fine, by the way, these 2 cisco 2960 made in Oct,08, I suspect the gi0/1 and 0/2 is defective, anyone has any suggestion?
royalblues Wed, 11/19/2008 - 00:18
Once you insert the SFP's the switches should detect and can be seen from the sh int status command
If they are not detecting, then i would suggest you raise a case with cisco and get RMA
