International Call configuration on T1 (CAS) - CM 4.2
tpatten
Need some insight on how to configure T1 CAS for international calls outgoing.
Dial-peer configuration is as follows:
dial-peer voice 120 pots
description International
numbering-type international
destination-pattern +011T
port 0/1/0:1
forward-digits all
Using CM 4.2 with a route pattern 9.011!#
discard digits predot Trailing-#.
we also tried adding a route filer to the pattern to include the international access, country code, etc.
We are Receiving a busy signal.
Also when dialing through the gateway it does not show any matching dial-peer.
Thank you for the assist
Brandon Buffin
Change your dial peer to:
destination-pattern 011T
Brandon
Thank you for the quick response. We made this change and added the "^". This has fixed the connection issue.
