Option 43 question
Answered Question
Nov 18th, 2008
My network has two different types of AP's, the 1130 and the 1242. I am using the Cisco switches to provide DHCP information to the AP's. If I read the directions correctly, I am supposed to use two different subnets for each model of AP?
Is that correct?
Correct Answer by cjoseph23 about 8 years 6 months ago
I have 1131s and 1200 APs on the same subnet. Here is the doc I used to configure the option 43 in my DHCP server.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00808714fe.shtml
Table 1 shows you the VCI you need for the 1240
Scratch this I see you are using the switch for DHCP. Yeah you will have to create different pools for each type of AP. Sorry about that.
Overall Rating: 4 (1 ratings)
Correct Answer
cjoseph23 Tue, 11/18/2008 - 16:05
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
