Console port speed "can't change" on 7204
Answered Question
Nov 18th, 2008
I'm trying to copy a new IOS from a laptop to the router via console port using hyperterminal.
I'm trying to change the console port speed and the 7204 does not like it.
This is what i am getting...
WWWRouter(config)#
WWWRouter(config)#line con 0
WWWRouter(config-line)#speed 115200
Failed to change line 0's speed
Can you guys tell me why i can;t change the speed?
Thank you,
Zeek
Correct Answer by Giuseppe Larosa about 8 years 5 months ago
Hello Zeek,
it is probably an older npe.
your config should be:
ip routing
int f0/0
ip address 10.10.10.1 255.255.255.0
no shut
you give 10.10.10.2 255.255.255.0 to your PC
you activate tftp server
from router
with dir /all verify if you have space on flash
verify you can ping the PC you need a cross-over cable or put both on two ports of a switch.
copy tftp flash
it will ask you all the parameters one per line
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Tue, 11/18/2008 - 12:04
  • Hall of Fame,
    Founding Member
Hello Zeek,
configure a LAN interface and use TFTP that is faster.
if it is an NPE-G1 or NPE-G2 you can use the built-in GE ports
just remember to put
media-type rj45 under GE config
so that you can connect to a switch or directly with a crossover cable and a laptop
with TFTP server running
Hope to help
Giuseppe
Zeek Ferraros Tue, 11/18/2008 - 12:08
I can see only 1 available fast ethernet port.
do you mind sending me a simple config for it, please?
Correct Answer
Giuseppe Larosa Wed, 11/19/2008 - 05:30
  • Hall of Fame,
    Founding Member
Hello Zeek,
ip routing
int f0/0
no shut
from router
copy tftp flash
Hope to help
Giuseppe
