profile.ini missing
Nov 18th, 2008
Hi guys,
I have a UCCX with HA deployment. The first cluster has profile.ini that is empty, no content in the text file (probably due to a power failure on the server). I Checked the profile.ini on the other server and it has data in it.
Is it safe to copy and paste the data from the second node to the empty profile.ini ?
ivillegas Wed, 11/26/2008 - 10:26
  • Silver, 250 points or more
Check the bug:
CSCso79779: Profile.ini file missing in a UCCX 5.0(2) High Availability setup
JimPatch01 Tue, 06/19/2012 - 10:35
Nicolas,
I know this is old. How did you resolve this problem? It happened to me today. I found this post and checked the bug. Still no workaround and it is terminated.
raj1000au Thu, 11/15/2012 - 18:40
I had the same issue. Copy the content in server 1 and paste in server 2, but change the ip address to point the server 1.
Save and re-boot the server 2 (had empty profile before). Should be fine. Cheers!!!
Raj
