7911G with PoE switch issue
Nov 18th, 2008
hello
i hearded somewhere that if you full all PoE ports on a switch with 7911G phones, there are resets very often. because i address the some problem with the specific ip phones on poe switches, does anybody know if there is any solution. Maybe a firmware upgrade for phones or the 2960E series switches which is new.
thanks
bkoum Wed, 11/19/2008 - 06:15
unfortunatly i dont have a cisco account to check this doc out but i hope u have right and there is no problem .
Rob Huffman Wed, 11/19/2008 - 07:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Bill,
This calculator does not have the 2960E but I did the calculation for the;
WS-C2960-24PC-L
With 24 7911 IP Phones and only 32.43 % of the available power was being consumed. So I don't see this as an issue.
Hope this helps!
Rob
bkoum Wed, 11/19/2008 - 09:29
ok so i guess that C3560E-48PD-SF which is more powerfull it cant behave strangly although im not so sure that all these sudden resets comes from power misconfiguration.in my situation the switch is a 500 express 25 ports and i hope 2960E and 3560E be more steady.
