2710 flashing led
Nov 18th, 2008
Our 2710 location appliance has a flashing amber led. Is there a means from WCS to determine what the issue is? If not what command at the LA would show the problem? I have rebooted the unit.
amritpatek Wed, 11/26/2008 - 09:15
  • Silver, 250 points or more
Blinking Amber Indicates an event has occurred such as open system lid, incorrect fan speed, temperature or power supply tolerance exceeded.
cef2lion2 Wed, 11/26/2008 - 14:30
Trying to find a CLI command that would display what the issue might be. Might just open a case on it next week.
cef2lion2 Tue, 12/02/2008 - 10:16
Talked to support. You need to plug monitor into video port and keyboard into USB. On startup you need to press F2 and go into 2710 BIOS setup and review then clear the event log. I had an issue with the BIOS date not being set.
Trending Topics - Security & Network
