Verifying SX + LH SFP's
Nov 18th, 2008
I need to verify if an SFP is inserted into a port and if its SX/mmf or LX/smf
Can someone clarify the following int outputs >>
Full-duplex, 1000Mb/s, media type is SX
Media-type configured as SFP connector
I was told that "" Media-type configured as SFP connector"" indicates NO sfp in the slot...NEED TO CLARIFY these two statements...thx.
jpoplawski Tue, 11/18/2008 - 14:25
I usually use the command show int status to show what type of SFP is plugged in. Typically anything not plugged in reports Not Present. It might be different per chassis/IOS version, however this is what I've typically seen on 3750's and and 3560's.
Hope this helps, rate if it does.
