Load balance using vlans on Catalyst & hp procurve final
Nov 18th, 2008
Just for closing this conversation.
Hello you all.
Well this is the MSTP configuration I think could work. The network schema is in the attachment.
& one more question witch software to use for simulating a catalyst 6500 or another MSTP capable switch?
Now the config(according to my schema):
DS1 (catalyst 6500)
interface Fasethernet 7/2
switchport mode trunk
switchport encapsulation dot1Q
switch trunk allowed vlan 1,2,3
switchport nonegociate
interface Fasethernet 7/3
switch trunk allowed vlan 2,4,5
interface Fasethernet 7/4
switch trunk allowed vlan 4,5,6
spanning-tree mode mst
spanning-tree mst configuration
name procurve-cisco
revision 1
instance 1 vlan 1, 3, 5
instance 2 vlan 2, 4, 6
spanning-tree mst 0-1 priority 0
spanning-tree mst 2 priority 4096
DS2(catalyst 6500)
name procurve-cisco
revision 1
instance 2 vlan 3, 4, 6
spanning-tree mst 0-1 priority 4096
spanning-tree mst 2 priority 0
AS1(hp procurve 2600)
vlan 1,2,3,4,5,6
vlan 1 tagged 25, 26
vlan 1 untagged 1-4
vlan 2 tagged 25, 26
vlan 2 untagged 5-6
vlan 3 tagged 25, 26
vlan 3 untagged 7-12
spanning-tree
spanning-tree protocol-version MSTP
spanning-tree config-name "procurve-cisco"
spanning-tree config-revision 1
spanning-tree instance 1 vlan 1 2 3
spanning-tree instance 2 vlan 2 4 6
spanning-tree 1-24 edge-port
AS2(hp procurve 2626)
vlan 1,2,3,4,5,6
vlan 2 untagged 1-4
vlan 4 tagged 25, 26
vlan 4 untagged 5-6
vlan 5 tagged 25, 26
vlan 5 untagged 7-12
spanning-tree
AS3(hp procurve 2626)
vlan 1,2,3,4,5,6
vlan 4 untagged 1-4
vlan 5 untagged 5-6
vlan 6 tagged 25, 26
vlan 6 untagged 7-12
spanning-tree
Thanks for any comments.
Giuseppe Larosa Wed, 11/19/2008 - 07:26
  • Hall of Fame,
    Founding Member
Hello Osvaldo,
the configuration looks like fine.
About MSTP emulation there are packages for instruments like Agilent router tester or IXIA but they work on dedicated hardware.
I don't know if under linux or freebsd you can find something useful.
Hope to help
Giuseppe
languedoc Sun, 11/23/2008 - 12:21
Hi Giuseppe.
I thank you very much.
You are very nice.
Thanks again.
I think I can close this conversation.
Bye
