Setting Boot System Commands
Answered Question
Nov 18th, 2008
  • Blue, 1500 points or more
TWO Quick stuipid questions:
(1) If a "dir flash:" gives the following output....
nhv-c14-sw1#dir flash:
Directory of flash:/
2 -rwx 676 Mar 01 1993 00:01:06 vlan.dat
3 -rwx 48 Nov 18 2008 23:10:24 private-config.text
5 drwx 192 Mar 01 1993 00:05:17 c3750-i9-mz.121-19.EA1c
85 -rwx 7755515 Nov 18 2008 16:42:33 c3750-ipbasek9-mz.122-35.SE5.bin
86 -rwx 17947 Nov 18 2008 23:10:24 config.text
15998976 bytes total (1775104 bytes free)
nhv-c14-sw1#
....and I want to configure a boot statement command to load the new IOS, do I need to add the "/"?
In other words, is it "boot system flash:c3750-ipbasek9-mz.122-35.SE5.bin
OR IS IT
"boot system flash:/c3750-ipbasek9-mz.122-35.SE5.bin
Do I need the forward slash after the word "flash:"?
(2) If I want to use the old IOS as a backup, I know I have to add it on the same boot system command line, but do I have to separate the 2 using a ";" and do I need the word "flash:" again or do I just start from "c3750"...?
In other words, is it "boot system flash:c3750-ipbasek9-mz.122-35.SE5.bin;flash:c3750-i9-mz.121-19.EA1c"
OR IS IT...
"boot system flash:c3750-ipbasek9-mz.122-35.SE5.bin;c3750-i9-mz.121-19.EA1c"
Im sorry to ask these seemingly inane questions but my problem is that I do NOT have a 3750 available in my lab to test with, and I will have to upgrade code during a window without onsite support. Theres no room for a mistake. I also cant seem to find the info on Ciscos website either.
Correct Answer by Edison Ortiz about 8 years 5 months ago
Very close, make sure to include the directory for the 12.1(19)EA1c IOS.
boot system flash:c3750-ipbasek9-mz.122-35.SE5.bin;flash:/c3750-i9-mz.121-19.EA1c/c3750-i9-mz.121-19.EA1c
.bin
Tested and verified on my 3750 here....
Overall Rating: 5 (1 ratings)
glen.grant Tue, 11/18/2008 - 16:38
  • Purple, 4500 points or more
To load a .bin file its just "boot system flash:c3750-ipbasek9-mz.122-35.SE5.bin . I believe you use the forward slash when you have to load the file out of a directory. It would be "boot system flash:c3750-i9-mz.121-19.EA1c/c3750-i9-mz.121-19.EA1c .bin .
lamav Tue, 11/18/2008 - 17:02
ropethic:
The 3750 does not allow more than one boot statement. You have to include the backup IOS on the same boot ststement command - separated by a semi-colon.
Glen:
I think youre right about the forward slash, but what about my 2nd question? How do I add the backup IOS string? Scroll up at my question for details about what Im asking.
Correct Answer
Edison Ortiz Tue, 11/18/2008 - 17:08
  • Hall of Fame,
    Founding Member
.bin
lamav Tue, 11/18/2008 - 17:17
Edison.
First, thank you!
Second, are you sure about the back slash (in the backup IOS part of the statement)?
Shouldnt it be a forward slash instead, like it is below?
.bin ?
Thanks again
Edison Ortiz Tue, 11/18/2008 - 17:27
  • Hall of Fame,
    Founding Member
Victor,
Good catch. I made the mistake while copying your entry from the post :)
I just checked the switch and indeed is forward slash.
__
Edison.
lamav Tue, 11/18/2008 - 18:07
Outstanding.
Thanks again!
