p2p blocking on Cisco IOS
Nov 18th, 2008
Is there any way to block any p2p traffic but not based on TCP/UDP ports but the content or certain pattern of the p2p packets on Cisco router?
I know use of NBAR but there can't be found all p2p protocols.
Thanks for any suggestions.
Remi
Overall Rating: 4 (1 ratings)
remi-reszka Wed, 11/19/2008 - 07:30
Thanks for your suggestions. I did take a look for the latest PDLMs and could not find any for ARES, LIMEWIRE or Bittorrent.
I am not sure if there are any PDLMs covering those applications. ARES is very nasty, uses dynamicly assigned ports from unspecified range.
I looked into ZPF config guides and it looks like with latest IOSs, Cisco added p2p applications for inspect so that with policy-map it could be policed to drop certain traffic maching certaing applications. Those features are available on 880 series for instance but I am working with 870 series.
Maybe you know of any PDLMs that would support ARES or LIMEWIRE.
Thanks a lot in advance.
Remi
remi-reszka Thu, 11/20/2008 - 15:56
Many thanks for additional clues but I guess ARES is not supported.
