WiSM Trunk Issue
Nov 18th, 2008
Anyone know how to reset the WiSM to factory defaults? Troubleshooting FAQ suggests resetting WiSM and entering "recover-config" at the username prompt, but that did not work. I made a change to one of the gig ports and it brought down the port-channel that's dynamically configured during initial configuration. Since I can't restore the port-channel, I need to start over...
Scott Fella Tue, 11/18/2008 - 19:45
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Reseting the WLC's in the WiSM will not restore your port-channel configuration. You need to re-configure your trunk port and the port-channel on the switch and you should be okay. The recover-config at the username will just clear the wlc config. Take a look at this doc... it might help you with the initial switch configuration.
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_tech_note09186a00808330a9.shtml
voilesadte Wed, 11/19/2008 - 07:40
That's how I configured initially. I have reconfigured the port-channels to the original configuration, but the high-order port-channel (that gets dynamically created when the initial port-channel was configured) can't be configured since the port-channel command only allows 1-256 and the Wism port-channel are above that.
The physical port channels are up/up, but the dynamic high-order port-channel status remains SD.
ericgarnel Wed, 11/19/2008 - 07:43
  • Gold, 750 points or more
Depending on which version of IOS you are running, it should re-create the channels on its own.
if you back out the wism config commands on the switch, it should create the interface/channels for you.
no wism service-vlan xxx
no wism module x controller 1 native vlan xx
no wism module x controller 1 allowed vlans xx,xx
do for controller 2 as well
and then re-add them.
afterwards, do the following:
sho wism status
sh wism module x controller 1 status
sh ether-channel xxx (what the wism/720 created) summary
Trending Topics - Security & Network
