Warning message
Caller ID validation using a cisco 3725
Answered Question
Nov 18th, 2008
I am relativly new ISDN and i was wondering how i would go about doing some sort of CLI verification on a number that has dialed into the router via an isdn pri line.
Regards Brad
Correct Answer by Giuseppe Larosa about 8 years 9 months ago
Hello Brad,
what is your current logging level ?
use sh logging to see your current setup.
sh isdn history could be helpful too
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
Giuseppe Larosa Tue, 11/18/2008 - 23:54
  • Hall of Fame,
    Founding Member
Hello Brad,
the isdn caller command given int interface serx/y:15 (E1 channel D) or serx/y:23 (T1 channel D) could be useful.
If using DDR the command can be given under interface dialer.
Hope to help
Giuseppe
brad.hodges Wed, 11/19/2008 - 15:49
Giuseppe
Thanks for your feedback, i will give it a go.
Regards Brad
brad.hodges Wed, 11/19/2008 - 22:02
Solution works brilliantly, however is there some way to log reject calls? as i cant see them in the log file.
Correct Answer
Giuseppe Larosa Thu, 11/20/2008 - 05:12
  • Hall of Fame,
    Founding Member
Hello Brad,
Hope to help
Giuseppe
brad.hodges Thu, 11/20/2008 - 15:06
Giuseppe
Thanks for your reply. i very much appreciate your help. My logging is currently set to informational which i will adjust to suite our needs.
Regards Brad
