Etherchannel load balancing and redundancy
Answered Question
Nov 18th, 2008
I config a 4+1 port etherchannel as:
port-channel load-balance dst-ip
interface Port-channel1
lacp max-bundle 4
What will happen if one of the active interface (for example the 3rd interface) in port-channel1 fail? Will the algorithm re-calculate the hashing? Or just switch the traffic from 3rd port to the backup port?
Correct Answer by Giuseppe Larosa about 8 years 4 months ago
Hello Alex,
the most efficient move is the second: the backup link takes the place of the failed link.
It should be possible because LACP messages are exchanged also on hot standby / backup links so the two devices can make a change on the fly with the backup link.
Hope to help
Giuseppe
Overall Rating: 4 (1 ratings)
Correct Answer
Giuseppe Larosa Wed, 11/19/2008 - 00:16
  • Hall of Fame,
    Founding Member
Hello Alex,
Hope to help
Giuseppe
