problem to forward traffic to one host in Catalyst 6506
Nov 18th, 2008
Hello. Do anyone see what the problem could be ?
There is a route in vrf (catalyst 6506):
Sw2#sh ip route vrf DMZ 10.249.17.0
Routing entry for 10.249.17.0/29
Known via "ospf 501", distance 110, metric 2, type intra area
Last update from 10.249.207.70 on GigabitEthernet1/1.2024, 00:01:12 ago
Routing Descriptor Blocks:
* 10.249.207.70, from 10.249.17.1, 00:01:12 ago, via GigabitEthernet1/1.2024
Route metric is 2, traffic share count is 1
And the same route for more specific hosts:
Sw2#sh ip route vrf DMZ 10.249.17.3
Last update from 10.249.207.70 on GigabitEthernet1/1.2024, 00:01:26 ago
* 10.249.207.70, from 10.249.17.1, 00:01:26 ago, via GigabitEthernet1/1.2024
Sw2#sh ip route vrf DMZ 10.249.17.4
Last update from 10.249.207.70 on GigabitEthernet1/1.2024, 00:01:34 ago
* 10.249.207.70, from 10.249.17.1, 00:01:34 ago, via GigabitEthernet1/1.2024
when i tracert to on host:
Sw2#traceroute vrf DMZ 10.249.17.4
Tracing the route to 10.249.17.4
1 10.249.207.70 0 msec 0 msec 4 msec
2 10.249.17.4 0 msec 0 msec 4 msec
all correct!!!!!
BUT when i tracert (or ping) to another host in the same subnet
traceroute vrf DMZ 10.249.17.3
Tracing the route to 10.249.17.3
1 * * *
2 * * *
switch don't reach next hop router!!!!!
There is not ACL on next-hop router.
I can't explain this behavior.
Thank you for any help
Giuseppe Larosa Wed, 11/19/2008 - 00:01
  • Hall of Fame,
    Founding Member
Hello Dmitriy,
to detect if there is a CEF multilaer switching issue on the C6500 you can:
add a static route in VRF for host 10.249.17.3
this should trigger a CEF recalculation and could be a temporary fix.
Another method could be that of adding an ACL outbound permitting everything but with the log option so that is not processed by normal CEF table.
We experienced similar problems but in global routing table for C6500 that receives full BGP tables from two border routers.
We performed also an IOS upgrade on the C6500.
Hope to help
Giuseppe
dimitavton Wed, 11/19/2008 - 00:49
hello Giuseppe.
thank you for answer.
but, unfortunally, you advice was not helpful.
neither adding static route, nor ACL with log option.
Giuseppe Larosa Wed, 11/19/2008 - 04:40
  • Hall of Fame,
    Founding Member
Hello Dmitriy,
I would move the focus on the next-hop router using the same "tools".
Hope to help
Giuseppe
