strip # from called party number
Nov 19th, 2008
My customer wants Agents to dial # after the Phone Number and if # is used then voice recorder is unable to play recorded voice call.
I am unable to strip # from called party number.
I)Call Manager Configuration
1)Route Pattern
Route Pattern 8.9!#
discard digits predot trailing-#
2)Service Parameter
"Strip # Sign from Called Party Number Required Field" set to True.
II)Voice Gateway Configuration
1)voice translation-rule
rule 1 /^9/ //
irisrios Thu, 11/27/2008 - 05:16
  • Silver, 250 points or more
This parameter enables the stripping of the # sign digits from the called party information element for the inbound, outbound, Q.931, and H.225 SETUP messages. Valid values specify True (strip the # sign) or False (do not strip the # sign).
The default value is True.
To stop the Cisco CallManager from considering # as end-of-dialing, set this parameter to False. This allows Cisco CallManager to send #.
To set the value of this parameter, choose Service > Service Parameters > CallManager service on the Cisco CallManager Admin page, and look for this parameter
Service Parameters Configuration:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_2/ccmcfg/b04svprm.html
