Which slot can Module WS-X4648-RJ45V-E be seated in 4510RE
Nov 19th, 2008
Dear Friends,
We inserted the above module in Slot 8/9/10 of the above switch. But it reports Unsupported module in show module command output. However, the same module works fine in Slot 1,2,3,4 and 7.
Does anyone have an idea on which slot in this chassis is this module supported?
The code running currently is 12.2(46)SG Enterprise services.
Thanks a lot
Gautam
Jon Marshall Wed, 11/19/2008 - 01:42
Gautam
From the 4500-E chassis Q&A
Q. Are there any restrictions on line-card placement in the Cisco Catalyst 4510R-E chassis?
A. The Cisco Catalyst 4510R-E supports only classic line cards in slots 8 to 10 with the Supervisor Engine 6-E.
Jon
