snmp linkdown traps
Answered Question
Is there any way to force a switch to only send linkdown traps for specific ports?
Do you just disable linkdown snmp in the global config then enable it on the port?
Matt
Correct Answer by Joe Clarke about 8 years 6 months ago
Switches are typically easier because you have the interface range command. Additionally, with a tool like CiscoWorks Resource Manager Essentials, you can deploy this change across a large number of switches quickly.
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 11/19/2008 - 09:44
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Other way around. Enable the traps globally, then configure:
no snmp trap link-status
Under the interfaces you do not wish to send traps.
Correct Answer
Joe Clarke Wed, 11/19/2008 - 09:51
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
