Monitoring IPSec Remote Access Users
Answered Question
Nov 19th, 2008
Hi all,
please can any one help me to know about monitoring Remote access users using ASDM. As I have observed in ASDM, it is possible to monitor users currently logged in, but what I want to monitor is users who were logged in since the firewall started (for example, 30 days)..
Thank you,
Nagabhushan
Correct Answer by JORGE RODRIGUEZ about 8 years 8 months ago
Nagabhushan, I do agree with Steven , you would need to use/implement logging.
Yes you can
in ASDM goto
Home/Configuration/Monitor/VPN/Session
Since you don't have any permanent logging setup to send logs to a syslog server for that amount of time you have already lost that information from 30 days ago, you need to implement syslog .
Go over this link for monitoring, you can also filter syslog messages based on log ID number or logging severity levels
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/monitor.html
Correct Answer by srue about 8 years 8 months ago
you really need to use your logs for that.
Overall Rating: 3.7 (3 ratings)
Correct Answer
srue Wed, 11/19/2008 - 07:50
  • Blue, 1500 points or more
Correct Answer
JORGE RODRIGUEZ Wed, 11/19/2008 - 10:11
  • Green, 3000 points or more
Yes you can
in ASDM goto
cpembleton Wed, 11/19/2008 - 16:44
  • Silver, 250 points or more
Syslog is the way to go. Just wanted to add something that will help on make syslog useful.
http://www.splunk.com
I use it for everything at home and work. There are free and enterprise versions.
Chad
