LMS 3.1 - How to find unused switchports?
sbrox
I need to find all switch ports that has been unused the last 30 days.
The report ”Reclaim Unused Up Access Ports” only shows access ports that were previously connected to an endhost
Joe Clarke
The report you mention is the way to do it, but you are correct. An end host must have been connected to that port at one time. This is the only way to achieve a baseline of when the port was last used, so a correct amount of idle time can be given.
