upgrading to full T1
Answered Question
Nov 19th, 2008
our company is upgrading to full T1 links from existing 512/1024 capacity. i will work with service provider and make the changes at same time in a conference call. i have a few doubts:
interface Serial0/0
bandwidth 1024
ip address 10.x.y.z
ip pim sparse-mode
encapsulation ppp
ip route-cache flow
no ip mroute-cache
random-detect dscp-based
service-module t1 timeslots 1-16
end
I follow these steps:
I first give a no service-module t1 timeslots 1-16 command and then tell the provider to make the changes at his end. As soon as i give this 'no' command i loose my remote connectivity and wait till provides changes it to full T1. I then get back my remote connectivity.
My questions is: if i leave the command service-module t1 timeslots 1-16 as it is and tell the provider to make the changes at his end, will i get back my remote connectivity or connection will be down unless i give 'no service-module t1 timeslots 1-16'.
i am doing this remotely so i do not want to be in a situation where i loose the connectivity forever
thanks
srinath
Correct Answer by Edison Ortiz about 8 years 5 months ago
If the provider makes their changes, it won't match your settings so they won't be connectivity.
I recommend having another way to connect to this router (modem via aux port, for instance) - just in case you need to revert back in your configuration changes.
Another trick is to make the change to full T1 in your router but before doing so, type reload in 10. This command will instruct the router to reload in 10 minutes and if the changes didn't work in your ISP side, the router will reboot with the previous configuration.
Make sure to cancel the reload if the ISP changes do work with the reload cancel command. You can also change the time interval .
HTH,
__
Edison.
Overall Rating: 5 (2 ratings)
Edison Ortiz Wed, 11/19/2008 - 18:40
  • Hall of Fame,
    Founding Member
If you are going to full T1, change the service-module to 1-24.
You will lose connectivity but once the provider makes the changes at their end, the connectivity will be regained.
You can't delete the service-module, you can only change the number of channels active in the service-module.
HTH,
__
Edison.
durga_suji Wed, 11/19/2008 - 19:34
Thanks for the reply Edison!
In case, i do not make any changes at my end and ask the provider to upgrade to full T1 at his end first. will i be able to regain connectivity?(i will still have service-module t1 timeslots 1-8) in my router? Will the connection be up or down in this case?
thanks
Correct Answer
Edison Ortiz Wed, 11/19/2008 - 20:03
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
