HWIC-AP Installation into 2811
Nov 19th, 2008
Kindly help me on how to configure my HWIC-AP wireless card into a 2811 ISR.
The HWIC-AP is already installed in the router. My running config is shown below:
interface Dot11Radio0/3/0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
Law
Overall Rating: 4 (1 ratings)
jeff.kish Wed, 11/19/2008 - 05:48
Well, I don't know how many SSIDs you want, and what VLANs you're using, so I'll assume a single SSID on the native VLAN. I also don't know what type of encryption you want, so I'll assume none for now. Finally, do you want the SSID to broadcast? I'll assume yes for testing purposes.
To create a broadcast SSID without encryption, perform the following configuration:
conf t
dot11 ssid ssid_name
authentication open
guest-mode
To configure the Radio, perform the following configuration:
conf t
int dot0/3/0
ssid ssid_name
channel 1
bridge-group 1
no shut
Finally, add an IP address on your BVI:
int bvi1
ip add x.x.x.x x.x.x.x
This should be good for testing purposes - let me know if it works. If you want encryption, more VLANs, etc... just post up and someone will be glad to help!
sr2470182 Wed, 11/19/2008 - 06:24
Thanks a million Jeff,
However when I tried to add an IP address into my BVI interface, I received the following error message:
"Integrated Routing and Bridging is not configured"
What should I do please?
sr2470182 Wed, 11/19/2008 - 08:02
I added the following command:
"bridge irb"
and I can now configure the BVI1 interface...
Thanks.
jeff.kish Wed, 11/19/2008 - 11:08
Ah yes, I left that command out. Sorry, it's been a while since I configured one of those.
Glad it's working!
