2 hub dmvp
Nov 19th, 2008
Hello
i have configured dmvpn
in the 2 cisco 7206 and then i configure spoke router i have a problem
i i configure in the spoke router only
1 hub router it's work good but then i add second hub in the spoke tunnels goes down it's my1 hub configuration
interface Tunnel999
bandwidth 512
ip address 10.10.9.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication test1
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip nhrp holdtime 300
delay 60000
tunnel source 213.131.X.X
tunnel mode gre multipoint
tunnel key 82042112
tunnel protection ipsec profile DMVPN
end
interface Tunnel998
bandwidth 1024
ip address 10.10.12.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication test2
ip nhrp network-id 2
tunnel source 92.51.X.X
tunnel key 75525350
second HUB
interface Tunnel999
bandwidth 512
ip address 10.10.10.2 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication test3
ip nhrp network-id 777
tunnel key 16713743
end
interface Tunnel998
bandwidth 1024
ip address 10.10.11.2 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication test4
ip nhrp network-id 778
tunnel key 26845508
SPOKE
interface Tunnel99
bandwidth 1024
ip address 10.10.11.4 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map multicast 92.51.74.42
ip nhrp map 10.10.11.2 92.51.74.42
ip nhrp nhs 10.10.11.2
ip nhrp cache non-authoritative
keepalive 5 3
tunnel key 26845508
end
interface Tunnel98
bandwidth 512
ip address 10.10.10.4 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map multicast 213.131.47.42
ip nhrp map 10.10.10.2 213.131.47.42
ip nhrp nhs 10.10.10.2
delay 60000
keepalive 5 3
tunnel source 92.241.X.X
tunnel key 16713743
so if in the spoke i have only this 2 tunnel dmvpn is work but if add second hub tunnel like this
interface Tunnel97
bandwidth 1024
ip address 192.168.9.2 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map multicast 213.131.36.150
ip nhrp map 10.10.9.1 213.131.36.150
ip nhrp nhs 10.10.9.1
delay 60000
keepalive 5 3
tunnel key 82042112
other tunnel goes down
