Mounting Antenna AIR-ANT2430V-R
Nov 19th, 2008
Our customer wants to mount the antennas with two screws through the sheet metal of the antenna on the suspended ceiling.
What exactly is the function of the sheet metal in the antenna ? Will my customer have less signal of that antennas? Does the antenna work fine with two screws in the sheet metal ?
Best regards
Heiko
scottmac Wed, 11/19/2008 - 09:21
  • Green, 3000 points or more
Without actually being able to look inside the case, I'd recommend against it.
Even assuming that you could drill through and not hit one of the active elements, any metal, conductive or not, ferrous or not, that close to the radiating elements will absolutely distort the pattern.
There is also a chance of increasing interference inbound or outbound (there are a lot of variables ... size of the screws, composition of the screws, proximity to the elements ...).
You may be making enough of an alteration to the antenna that it no longer is acceptable as similar to the product licensed by Cisco to sell in your city/county/state/country; meaning that o remain legal, you may have to have it re-certified.
The antenna comes with clips to attach it to (at least) two types of drop ceiling. Why not just use the clips?
Good Luck
Scott
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
