2960 - 48
Answered Question
Nov 19th, 2008
  • Purple, 4500 points or more
Anyone know how many etherchannels this model will support ? The 24 port versions are restricted to 6 , do the 48 port versions have the capability of more than 6 . Can't seem to find the answer anywhere in the switch product data sheets .
Correct Answer by ropethic about 8 years 6 months ago
taken from following link
EtherChannel Configuration Guidelines
If improperly configured, some EtherChannel ports are automatically disabled to avoid network loops and other problems. Follow these guidelines to avoid configuration problems:
•Do not try to configure more than 6 EtherChannels on the switch.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_see/configuration/guide/swethchl.html#wp1275481
Overall Rating: 5 (1 ratings)
Correct Answer
ropethic Wed, 11/19/2008 - 07:09
  • Silver, 250 points or more
glen.grant Wed, 11/19/2008 - 08:43
Ok , thanks that rules out a bigger 2960, will have to go to a 3560 to get more port channels.
