SRST - phones do not get extensions assigned to them.
Nov 19th, 2008
I see the phones register on the gateway. Only they do not get extensions.
I have attached the run...
allan.thomas Thu, 11/20/2008 - 03:06
If you could advise what IOS you are using, it could help narrow possible known issues.
When the phones re-register are the voice dial-peers created with the approriate number 'show dial-peer voice summary'? Or is the number missing also?
Could you also try removing the keword preference 1 from max-dn, by default the preference is 0, so it should not be necessary in your case. 'no max-dn', and then 'max-dn 42.
Can you post the output of the show 'ccm-manager', 'show call-manager-fallback', 'show dial-peer voice summary', and 'show ephone summary' whilst in SRST.
Hope this helps
Pls rate helpful posts.
dezoconnor Thu, 11/20/2008 - 04:47
Agree with the posts below. Check your IOS on the Voice Gateway and the firmware running on the phones, more than likely a compatibility issue.
dconstantino Thu, 11/20/2008 - 06:32
I think it is his IOS it you look at the IOS version under the sh run in the Boot system command he is running 12.4-23.
No T No other numbers letters ect. sound fishy and old to me.
in order to assign the extensions, wouldn't you need to specify the MAC address and the extension numbers?
On our config we have something like the following for each of the phones -
ephone-dn-template 1
call-forward busy 1010
call-forward noan 1010 timeout 20
pickup-group service
ephone-dn 1 dual-line
number 5500
description Kris 5500
name 5500
ephone 1
mac-address 0007.0E16.13C7
button 1:1
michaeljbyrne Thu, 11/20/2008 - 07:51
I finally Figured it out yesterday after I posted this.
I needed to be in SRST mode 4.1 because I was using 7975's
norm.trees Mon, 11/24/2008 - 10:02
Hi, I have this issue with 7942`s and 7945`s using SRST version 3.3, does this mean a complete IOS upgrade to get the updated SRST or can you download some kind of component?
Hope you can help.
