Single Sig On
I have been looking into single sign on (SSO)and need some guidance if anyone can help as I am finding it more confusing the more I look at it.
Windows XP does not support SSO
Windows Vista supports SSO
I can use the CSSC as a suplicant to enable SSO in Windows XP.
I can use a NAC to enable SSO in XP.
Not sure if this is correct?
Also I am limited on the security protocols that I can use with SSO?
justin_miller Tue, 11/25/2008 - 14:21
Looks like what you have there is all correct.
What kind of hardware do you have for client cards? Intel proset can be setup in Windows XP to do a prelogon/SSO
There shouldn't be any limitations to your security protocol, I have mainly uses MSchapV2 and EAP-Fast.
Hope some of this helps, and let me know if you have questions
Trending Topics - Security & Network
