LMS 3.1 RME Device shows up twice
Answered Question
Nov 19th, 2008
I have a Cisco CSS 11501 and it is showing up twice in RME. Once with the host name and once with the IP address. It does not show up as an Alias Device in RME Device Management. How do I get rid of one of them?
Correct Answer by Joe Clarke about 8 years 5 months ago
No. It should be built into the CSS. However, I found a bug where that table is broken, CSCdw90592. This means the alias/duplicate resolution code in LMS will not work properly. However, you can get around this by picking the instance of the device you want to keep, then delete the other one from DCR. Provided that Discovery properly identifies the device the way you want it, the duplicate should not return.
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 11/19/2008 - 09:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Was this an upgrade from LMS 3.0.1?
Joe Clarke Wed, 11/19/2008 - 10:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Then there may be an SNMP issue with this device. Please post a screenshot showing how both instances appear in the device selector.
Joe Clarke Wed, 11/19/2008 - 10:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post SNMP walk output for the ifTable and ipAddrTable branches from this device.
Joe Clarke Wed, 11/19/2008 - 12:17
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is the ifTable, but I don't see the ipAddrTable here. That table is used to identify aliased devices. The OID is 1.3.6.1.2.1.4.20.
troymaki Wed, 11/19/2008 - 12:47
How do I get that OID to show up on the 11501? Can I add it somewhere?
Correct Answer
Joe Clarke Wed, 11/19/2008 - 13:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
troymaki Wed, 11/19/2008 - 13:55
I deleted the unwanted device and ran a Discovery. Once the Discovery was done, the device showed back up as Newly Added. I then deleted the one I wanted to keep and ran another Discovery. It now only shows 1 of them. I tried to sign up for the bug tracker but it says info on this bug is only available to cisco employees. Anyways, thanks for the help again.
Joe Clarke Wed, 11/19/2008 - 14:25
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The bug will never be fixed. The CSS developers only add ipAddrTable entries for physical interfaces, and this is by design.
