pkumarap Fri, 11/21/2008 - 01:59
use boson simulator.you can search in google.gns3 needs good memory to run.if your pc config is not good your pc hangs.
johnlloyd_13 Tue, 11/25/2008 - 08:57
boson has limited command set on it. i tried using it first then switched to dynamips. it's way better than boson!
tnphoneman Tue, 11/25/2008 - 11:03
I don't know if it as good, but I actually bought the Cisco Virtual Labs software by Wendell Odom. I figured that it had to be pretty good. It was on sale and was quite a bit cheaper than the Boson stuff.
