Site VPN without a static IP
Nov 19th, 2008
Hi. We have a remote site that connects to the internet via a Cisco 1801 Integrated Services router plugged into an ISDN line. Ths line only has dynamically assigned public IPs and I'm wondering if it's possible to create a site VPN back to our head office Pix 515 without a static IP at the remote site. Any pointers would be greatly appreciated.
I should also point out that this site already connects to head office via an ADSL line connected to the 801 with a static IP which is working fine. The ISDN is for backup.
Overall Rating: 5 (1 ratings)
Jon Marshall Wed, 11/19/2008 - 09:01
Yes you can do this. Have a look at the following link -
If you also have VPN clients coming into the same device you may want to look at this doc as well -
Edit - i forgot to point out. Because you use as the remote IP address to allow dynamic connections that means any remote device could try and setup a tunnel with your pix. Obviously the device won't be able to without the key but it becomes evern more important to use a secure key.
