CCM 4.2(1) question
Nov 19th, 2008
Hi to all,
I have a CCM cluster ( 1 Publisher and 2 Subscribers ), 1 Unity 4.0(5) and my question is thar the unity hunt pilot has disappeared from the CCMS, is there any way to know when it happened and who delette it, i have been looking into the event view but nothing.
Best regards
Jaime Valencia Wed, 11/19/2008 - 08:53
no, no native logging on that.
only possible way would be to go to IIS logs and review them until you find at what time someone did it, then if MLA enabled look at what time someone was logged in. if several users logged at the same time no way to find out who did it.
reviewing iis logs is also not easy task, you need to know the whole url string to delete something
if this helps, please rate
