ericgarnel Wed, 11/19/2008 - 09:42
  • Gold, 750 points or more
Are you running windows or Linux?
the apache conf files are buried under the WCS-X.x.x/ directory. For the ssl port under Linux, edit ssl.conf under /opt/WCS4.2.110.0/webnms/apache/ssl (or whatever your version is)
for port 80, edit httpd.conf under
/opt/WCS4.2.110.0/webnms/apache/conf
The files should be the same in either OS, but the locations are different
nshoe18 Wed, 11/19/2008 - 09:49
It is windows. I will give it shot. Thank you.
Pushkar Sambhoos Mon, 12/08/2008 - 23:32
  • Cisco Employee,
Easiest way is to take a backup. Then uninstall WCS, reinstall it and set the correct port during installation. Then perform a restore.
ericgarnel Tue, 12/09/2008 - 06:43
That seems like a lot of work compared to editing a conf file and restarting the service
Pushkar Sambhoos Tue, 12/09/2008 - 07:30
  • Cisco Employee,
That is the only supported way of changing HTTP port in versions 5.1 and below. Starting with v5.2, this setting is available under Administration --> Settings.
Trending Topics - Security & Network
