CUCM6 : VideoTelephony with 3 users: is it possible?
Nov 19th, 2008
Is it possible to do a 3 conferencing using a CUCM ?
i.e after calling one person, I call another person using the conference adhoc and both will be in conference with me.
thks.
Overall Rating: 5 (1 ratings)
jbarcena Wed, 11/19/2008 - 09:12
No, it is not possible the conference will be done but only with audio and no video.
For Video-Conference you need to have the MCU to join the 3 video streams.
jmaat Mon, 12/01/2008 - 04:26
Hi, do you know if there is any way I can test the MCU? Is there some kind of emulator/simulator available?
jasoninbtr Mon, 12/01/2008 - 05:59
You might try Stonevoice's software MCU. I have never used it but I have heard good things about thier products. I believe it is going to integrate to CCM via h323 so you won't be able to use ad-hoc style conferencing (IE - pressing the Conf button on the phone). More than likely you will have to have all of your endpoints dial a number to be connected to the MCU.
http://www.stonevoice.com/Products/SoftwareMCU/tabid/975/Default.aspx
Hope this helps.
Jason
