IP VERIFY UNICAST REVERSE-PATH
Answered Question
Nov 19th, 2008
Hi everybody,
Please can someone tell what the above command "ip verify unicast reverse-path" does or achieves on a router interface. I discovered that when it is set on an interface I cannot ping the interface.
I was wondering if it is a security device, if disabling it will have any adverse security risk to my network.
Correct Answer by ajagadee about 8 years 5 months ago
Tom,
Below is an excellent document that should answer most of your questions on URPF.
http://www.cisco.com/en/US/docs/ios/11_1/feature/guide/uni_rpf.html#wp1042332
Arul
*Pls rate if it helps*
Overall Rating: 5 (1 ratings)
srimural Wed, 11/19/2008 - 20:20
Hey,
It is a security hardening command which can check the integrity of the source ip address. it protects from attacks like ip spoofing and all. a number of common types of denial-of-service (DoS) attacks, including Smurf and Tribe Flood Network (TFN), can take advantage of spoofed or rapidly changing source IP addresses. I hope i have helped a little. if you find anymore info do let me know
Thanks and Regards,
Srinath Muralidharan
Cable&Wireless
+91 99809 30364
