All Routers Interfaces bouncing every 4-5 hours.
Nov 19th, 2008
I have a 7206VXR connected to a 2950 ethernet switch via one FastEthernet port.
Every 4 hours or so, I see the all the Ethernet ports go DOWN for a few seconds and then back UP. Only one interface is actually connected, but all four go down/up even though the other three are admininistrively down.
The Switch port and Router's Interface are free from "errors".
Here's the log,
I am a little unsure what/how to debug this.
*Nov 19 03:41:08.199: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed stat
e to down
*Nov 19 03:41:08.199: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed stat
e to down
*Nov 19 03:41:08.199: %LINK-3-UPDOWN: Interface GigabitEthernet0/3, changed stat
e to down
*Nov 19 03:41:08.199: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state t
o down
*Nov 19 03:41:10.947: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state t
Any ideas appreciated.
This router is running OSPF, HSRP and a VPN service, nothing too complex.
thank for reading
MAtt
Giuseppe Larosa Wed, 11/19/2008 - 10:15
  • Hall of Fame,
    Founding Member
Hello Matt,
I can tell you that we opened a TAC SR, because we noticed this on several ports of C2950 that are in different remote sites there are events like this.
At first we thought a problem of interoperability with Cisco IP phones but then a network analysis showed the problem also on ports with directly attached PCs.
The problem started in one site, where we replaced the original C2950 with another one but the problem was still present.
Current TAC suggestions include to try to fix speed and duplex to see if the behavior change.
The case is still open.
So the problem can be on the C2950 side as well.
Look at c2950 log to see if multiple ports are affected
Hope to help
Giuseppe
johnlloyd_13 Thu, 11/20/2008 - 07:28
  • Blue, 1500 points or more
I agree with Guiseppe to double check the duplex/speed settings. Besides the syslogs, could you post the config on both interfaces?
mcroft Thu, 11/20/2008 - 07:36
Hi Guys,
Thanks for the response, but both the Router and Switch are hard set to 100 Mbps / Full duplex, see here ....
Router:
interface GigabitEthernet0/1
ip address x.x.x.x 255.255.255.0
ip nat outside
ip virtual-reassembly
ip route-cache same-interface
ip ospf hello-interval 20
duplex full
speed 100
media-type rj45
no negotiation auto
standby 1 ip x.x.x.40
standby 1 timers 20 30
standby 1 priority 160
standby 1 preempt
Switch:
interface FastEthernet0/11
switchport access vlan 3
no ip address
duplex full
speed 100
spanning-tree portfast
